Extremely Low Resistor Values?
Discussion in 'General Electronics Chat' started by mossman, Feb 19, 2014.
  1. mossman
    Aug 26, 2010
    131
    I'm reverse-engineering a small circuit board and there are several extremely low value resistors. A couple are 4.7 ohm and there is a 1.9 ohm and a 1 ohm as well. A couple of them are connected from a microprocessor pin to ground. What is the purpose of these low value resistors and aren't they essentially a short circuit? FYI, I know for a fact that they are resistors and not inductors.
  2. nigelwright7557
    May 10, 2008
    488
    71
    I usually use small value resistors for measuring current.
  3. #12
    Nov 30, 2010
    16,655
    7,293
    No, they are not essentially a short circuit. 4 example, a row of NPN power transistors acting as the output of a power supply often use less than 1 ohm each to get the transistors to share the current more equally.
    Metalmann likes this.
  4. mossman
    Aug 26, 2010
    131
    Okay, but why would a microprocessor use several low value external resistors? Why not make them internal to the processor IC? Is it to dissipate heat since they are such low values?
  5. studiot
    Nov 9, 2007
    5,005
    515
    What microprocessor and which pin?
  6. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Low value resistors are usually high power resistors, and they don't fit well in ICs. Mouser or Digi-Key carries them.
  7. alfacliff
    Dec 13, 2013
    2,449
    428
    low value resistors are becoming more common, a 1 meg ohm resistor dosnt pass much current at 3.3 volts or 5 volts.
  8. mossman
    Aug 26, 2010
    131
    The processor is made by Samsung and there is no datasheet available so I don't know the pinout. As an example, there is a 0.6 ohm resistor connected in series between two pins in one location and a 1.8 ohm resistor connected from another pin to ground. I'll assume they are power resistors then.
  9. Veracohr
    Jan 3, 2011
    559
    77
    You really shouldn't assume what role the resistors have without knowing what they're connected to.
  10. spinnaker
    Oct 29, 2009
    5,062
    1,159
    They are most likely not "power" resistors. They are more than likely current sense resistors. But without a schematic and datasheets it is only a guess.
    Good luck with reverse engineering a product that you know nothing about.
  11. WBahn
    Mar 31, 2012
    18,065
    4,905
    They could be there for a number of reasons. Perhaps the pins in question need to be logically tied to ground and the choice was made to tie they through resistors for current limiting or noise considerations or who knows what else.
    Perhaps they are biasing resistors for some analog circuitry that is part of the chip.
    Why are you trying to find out?
  12. spinnaker
    Oct 29, 2009
    5,062
    1,159
    See first post. OP is trying to reverse engineer a small circuit board containing a chip to which the OP has no datasheet or schematic.
  13. WBahn
    Mar 31, 2012
    18,065
    4,905
    Ah. Yes. I guess I tuned that out as my first reaction was, "Hey, I've got a board with some components on it. Can anyone tell me what they do?"
  14. mossman
    Aug 26, 2010
    131
    I apologize for being vague, but I have no choice but to be vague. I was just looking for a general answer as to what these extremely low value SMD resistors are typically used for.
  15. studiot
    Nov 9, 2007
    5,005
    515
    I am not complaining about 'vague'.
    But it is in your interests to supply all the information you can.
    So what did this board come out of?
    Was it a preprogrammed washing machine controller?
    Do you have any idea whether this is a 4 bit, 8 bit, 16 bit micro or what?
    How many pins does it have?
    What does it look like?
    Size, pins to a side?
    Markings?
    etc etc
  16. wayneh
    Sep 9, 2010
    12,362
    3,220
    And let's not miss the obvious: How sure are you that you are reading the resistances properly? A photo might help folks see something you are missing.
  17. mossman
    Aug 26, 2010
    131
    I'm measured them using a high precision instrument (LCR meter). They are not inductors.
  18. kubeek
    Sep 20, 2005
    4,686
    805
    Could you post a photo or two? Basically all smd resistors I have ever seen have a value written on them. Could the die of the chip in question be fried and thus skewing your measurement? Have you taken some off the circuit and measured them alone?
    And more importantly, what was the purpose of that board, or where did it come from?
  19. mossman
    Aug 26, 2010
    131
    Again, I can't provide any details. Sorry. There are no markings. Even if they did have markings, they are so tiny that you wouldn't be able to read them without a microscope. They have all been removed from the board and measured using an LCR meter. I already know the values. I'm just curious as to what the purpose is, in general, for such low value resistors in a microprocessor application.
  20. kubeek
    Sep 20, 2005
    4,686
    805
    Well, if you can´t provide details, then you should not be asking questions.
    If you cannot say what the device does or any other detail apart from the fact that you found a few low value resistors, then this thread is completly pointless and you might as well close it.
