extracting data from GPS pls help
Discussion in 'Embedded Systems and Microcontrollers' started by pawankumar, Jan 19, 2012.
  1. pawankumar
    Oct 28, 2009
    42
    Hi friends,
    I tried interfacing GPS module with PC to extract the co ordinates (lat,long)
    As soon as I connected the device to serial port @9600 baud, it started spitting data.
    as per NMEA(pretty straight forward), I extracted latitude and longitude from the $GPGGA string. but every time I land up to a place about 30Km away from home :( .
    Then I used the software GPSCockpit, which provided the exact co-ordinates of my house. This is mystery to me.
    for instance,
    a GGA string i received is like:
    $GPGGA,075529.844,1307.2917,N,08012.5775,E,1,4,1.34,30.2,M,-88.5,M,,*40
    this gives the (lat, long) data 13.072917N,080.125775E
    but the original co ordinates are (13.121540,80.209590)
    How do I get this? I ve done a lot of google search to ensure no one else has faced a similar problem. Please suggest me proceed further.
  2. pawankumar
    Oct 28, 2009
    42
    someone please help me....
  3. davebee
    Oct 22, 2008
    539
    46
    The numbers that look bad are timestamped 7:55:29, but the good numbers are timestamped 7:55:50.
    If you compare readings of about the same timestamp, do they still show about the same 30 km offset?
  4. pawankumar
    Oct 28, 2009
    42
    @davebee :
    Thanks 4 your response. I am experimenting this with my desktop. so, no chance to move .
    I feed the raw data into this site, it gives me the exact location
    http://youngindia99.com/gps.aspx
    There are many such apps.but I just need the method how these guys do it
  5. pawankumar
    Oct 28, 2009
    42
    Got it!!!!
    this one seems to work
    to convert NMEA co ordinates into google understandable co ordinates,
    NMEA===================>Google understandable
    1307.2917===>13+07.2917/60 =13.12152
    this is a blind guess work
    anyone knows the logic please let me know
  6. davebee
    Oct 22, 2008
    539
    46
    Google must give the location in fractions of a degree instead of in degrees, minutes and seconds.
    0.12152 degrees * 60 minutes/degree = 7.2912 minutes
  7. kubeek
    Sep 20, 2005
    4,691
    806
    Read your datasheet and find the exact data format used, 13.121540° is 13°7'17.544" which is exactly the error youre seeing.
  8. pawankumar
    Oct 28, 2009
    42
    Yeah.... I get it now... thanks guys :)
