Extra functions on multimeter.
Discussion in 'General Electronics Chat' started by studiot, Jan 23, 2015.
  1. studiot
    Thread Starter AAC Fanatic!
    Nov 9, 2007
    5,005
    515
    In the early 1980s I had a multimeter / calculator combined.
    Readings from the multimeter could be transferred into the calculator for further processing.
    At that time I wanted a logic (TTL & CMOS) facility incorporated but could never find one, until now.
    I have just taken delivery of a new multimeter that incorporates CMOS and TTL test settings.
    Now I am having trouble finding some (ancient?) TTL/CMOS circuitry to test!
    What other goodies have people seen / would they desire in a multimeter?
    http://forum.allaboutcircuits.com/attachments/hioki-jpg.4695/
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    A graphical display so you know what the frequency measurement function is measuring.
    John
    #12 likes this.
  3. #12
    Nov 30, 2010
    16,703
    7,338
    +1
    99% of the time, I don't need a graph, but it would be wonderful to have a little window that shows me if there is DC under my AC reading or AC riding on what I thought was only DC.
    bwilliams60 likes this.
  4. wayneh
    Sep 9, 2010
    12,388
    3,244
    A multimeter that is really a handheld oscilloscope sounds sweet to me.
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Since oscilloscopes themselves have shrunk to just about hand held sizes I'll just keep using my scope as a scope, thanks.
    I like a DVM to be small and relatively simple without a lot of setting to make to make a measurement. I like when I can just set the type (ACV or I, DCV or I, or ohms), tap the circuit for one reading and hit the range button so it sticks. I'm not a huge fan of autorange and get it off as soon as it's done it's job once.
    My standby cheapie from Radio Shack went extremely out of cal (+20% on AC voltage) just before Christmas so I asked for a RS replacement to make it easy for her to find when she demanded some sort of gift list from me.
    It works, like it so far, except it came with a temperature probe and a weird USB cable ("A" plugs both ends) that stay in the box.
    Which means now I have to keep the box so I have another piece of something floating on my work desk.
  6. Externet
    Nov 29, 2005
    780
    58
    Hi studiot.
    The feature I would like is the audible continuity tester. But not the typical beeper found in modern meters.
    Could be just an additional very simple circuit to the multimeter, powered by only one 1.5V of the cells inside the multimeter. The multimeter can be off. Independent probe jacks for such.
    I have the gadget in a separate box, and use it very often. Integrating such into the multimeter would be great.
    Tone is 440Hz for zero ohms, and rises to about 1KHz for say 10 ohm. Discussed previously here :
    ----> http://forum.nutsvolts.com/viewtopic.php?f=45&t=7132&hilit=continuity
    ----> http://www.electro-tech-online.com/threads/audible-tones-continuity-tester.139251/
    ----> http://www.edaboard.com/thread306989.html
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    They've been around for years.
  8. MrChips
    Oct 2, 2009
    12,635
    3,454
    DC, AC Volts
    DC, AC current
    High current range (20A)
    Ohmmeter
    Continuity test, audible output
    diode test
    capacitance
    frequency
    BJT beta (optional)
  9. studiot
    Nov 9, 2007
    5,005
    515
    Is that for heating the coffee?
  10. MrChips
    Oct 2, 2009
    12,635
    3,454
    The DMMs I have seen have current ranges to 200mA. Then there is a separate switch setting and input for 10A or 20A range.
  11. ian field
    Oct 27, 2012
    4,447
    791
    All mine have a separate socket for tens of amperes ranges.
  12. GopherT
    Nov 23, 2012
    6,312
    4,031
    Yes, A thermos or coffee maker would be a great addition.
    Lundwall_Paul likes this.
  13. ian field
    Oct 27, 2012
    4,447
    791
    A few decades ago, one of the magazines published a coffee keeper warmer to use up all those rusty 2N3055s laying about in the junk box.
  14. studiot
    Nov 9, 2007
    5,005
    515
    Yeah I ground up a whole sack of 3055s, but I'd say the taste was a bit odd.
    Perhaps I didn't roast them properly first.
  15. ian field
    Oct 27, 2012
    4,447
    791
    Might have worked better with TIP3055.
