I have a device that I would like to monitor its voltage in relation to its temp.
Is there any simple device that I can use to get both a temp and voltage reading to a linux PC?
I also want to control the thermal chamber via GPIB, any ideas on a good device?
I also want to toggle the device on and off... by somehow shorting a line to ground or letting it float high.
Since I want to accomplish these 4 things, is there a better solution then 2 DMM's a GPIB controller and some other device to toggle the unit on and off?
I look forward to what others have in mind.
Thanks!
Thanks!
