external Hard drive problem
Discussion in 'Computing and Networks' started by Eric007, Jun 26, 2012.
  1. Eric007
    Thread Starter Senior Member
    Aug 5, 2011
    1,055
    33
    I have an external hard drive with important stuff in there...
    I connected it to a friend's laptop to send some files...and it was taking for ever so I decided to disconnect it manually as the 'eject' was not even working as the machine froze...
    Now back to my machine, it doesn't want to open nomore!
    It say' you need to format the disk in drive F: before you can use it'
    But I CANNOT do that!
    Any help!?
    Thanks!
  2. luvv
    Member
    May 26, 2011
    186
    31
    Remove it from the enclosure and driver,install it in a pc.
    Could be a issue w/ the driver itself( the enclosure and adapter that holds the HDD)
    If that's the case, a replacement is very cheap.
    Eric007 likes this.
