A good way to visualize it is to see the low resistance wire and connections as guides for electrical energy but not the media for energy movement. When resistance is low the energy movement is pointed into the space around the conductors so very little of the energy is absorbed into the conductor particles resulting in little heating. When resistance is high the direction of energy movement tilts more toward the resistive conductor as the media for energy movement as electrical energy is converted to heat as it is absorbed into the resistance.The physics of the particles bouncing around and moving is what causes the heat isn't it?
That being said, are those particles likely to dam up at the exit end (socket), and bounce around in a tighter space, causing extra heat?
If not at the prong end, but only at the socket end, then maybe physics is playing a role?
If they all do it, then what is the worry?
Just don't run the cord under the carpet.
Heck, I don't know!
Interesting thread.
So if the cords connections are electrically resistive IRT the rest of the wiring, electrical energy will be pulled into those locations causing them to heat at a higher rate than the rest of the circuit.
