Extending FFC Cables....
Discussion in 'The Projects Forum' started by sprockett, May 28, 2013.
  1. sprockett
    May 28, 2013
    Hi there,
    I have a 24pin 0.5mm pitch FFC cable which I hope to extend using a FFC Jumper cable.
    I did a search on best ways to do this:
    1. MANUALLY SOLDER (Difficult)
    http://forum.allaboutcircuits.com/showthread.php?t=43394)
    --> I really hope to avoid this as I have REALLY bad soldering experience.
    2. Buy a Extension circuit board (hard to find in 24pin)
    http://www.ebay.com/itm/40Pin-to-40...extension-flat-cable-FFC-extend-/360622317055
    --> I know the above is 40pin. But would it not be possible to just slot in a 24pin (so i don't really use the remaining pins), as long as the "pitch" is correct? This would be great since 24pin version is unavailable.
    3. Use a normal FPC adaptor to compress two FFC ends together??
    http://kyorune.com/modding/article.php?id=63
    --> This seems like the simplest and easiest way... But is it really THAT simple? Buy a 24pin adaptor, and stuff two FFC ends inside and clamp it down?
    Appreciate any comments / help.
    Thanks!!
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    I had no idea what is an FFC cable and had to look it up.
    I would usually call this a ribbon cable.
    Solution: Make a new cable of the desired length.
    Edit: I now have to assume that FFC refers to those ribbon cables that use no connectors on the ends. In that case I have no solution to offer.
