Extending battery life with parallel batteries?
susannah
Joined Feb 14, 2010
87
I want to extend time i can use my Olympus voice memo recorder.
It uses one AAA battery.
Can i just solder wires to battery bay + and - contacts and put many AAA batteries in parallel?
Kermit2
Joined Feb 5, 2010
4,162
That would be acceptable. Do not mix battery types. Batteries should all have the same charge state. Don't mix old and new batteries.
MrAl
Joined Jun 17, 2014
11,496
Yes AA batteries are about twice as 'strong' as AAA batteries. They can run something two times longer.
Also, the batteries have to all have the same voltage.
When functioning off of one battery, the battery experiences a discharge rate of I*K where K is a constant and I the current, but when we divide the current by 2 (two equal batteries in parallel) the discharge time goes up by a factor that is greater than 2 because of the P factor of the battery, which means that the ampere hour capacity actually goes *UP* with lower current levels.
The usual test level is C/20, and at higher currents the run time goes down by the ratio of C/20 to the actual discharge current level, minus a little more, but at lighter currents it goes up by a little bit more.
So at lower current levels the batteries look like they are bigger than they really are. That means more than twice the run time from two equal batteries in parallel.
Some care has to go into the matching of the two (or more) however.
wayneh
Joined Sep 9, 2010
17,498
Be careful if you buy a commercial battery pack, such as one for holding 2 or 4 AAs. They are usually wired to put the cells in series instead of parallel. This would over-voltage your device.
34,465
Depending upon how long you want the device to operate, just use an AA, C, or D cell, as mentioned by tcmtech.
They have the same capacity as about 2, 6 and 12 AAA cells respectively.
MrAl
Joined Jun 17, 2014
11,496
I dont know if anyone has every taken a 9v alkaline battery apart, but they used to house AAAA batteries inside. Many of them now have little flat batteries stacked in series.
The little AAAA batteries where skinnier than the AAA batteries.
