hello,
I'm trying to extend USB cable to power webcam for security reasons - I need the webcam to be far away from a computer. I know there are USB extender I can buy but I m trying to do it myself if possible.
My experiment so far have yielded the following results and would like to get feedback on them. Basically due to the length of cable the extension would only work for low-intel devices like keyboard/mice but not for webcam and USB drives. From Ubuntu /var/log/syslog I can see unstable connection to the device on and off, one minute the webcam is connected but then it drops off...etc. So what is a way to extend the USB cable so it can power high-intel devices like webcam ?
NOTE : I don't believe the problem is the voltage drop due to cable length since I measured the volts at far end of the extension and it comes out to 5+ volts for USB red wire.
Extend with 2 or more USB cables
CONNECTION : each USB cable is roughly 5 ft long
RESULT : webcam can only be connected properly with less than 2 USB cables, with 3 cables the device would connect on and off.
Extend with traditional phone line
CONNECTION : phone line has 4 wires so I simply connect them to USB cable's 4 wires. Phone line is roughly 25 ft.
RESULT : webcam would connect and drop off...etc
Extend with CAT5e - connection 1
CONNECTION : CAT5e has 4 pairs of twisted wires. I connect each pair to one USB wire. CAT5e cable is roughly 25 ft.
Extend with CAT5e - connection 2
CONNECTION : I give USB red(+5) and USB black(ground) 1.5 pairs of CAT5e twisted wires each and only 1 wire for USB D- and D+. So from the 8 total wires out from the CAT5e, 3 wires goto USB red, 3 wires goto USB black, 1 wire goes to USB D+ and 1 wire goes to USB D-
Thanks.
Thanks.
