Hi
I have a 4 channel relay box that uses an RF signal (I think) from a key fob to activate circuits. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250650687475&ssPageName=STRK:MEWNX:IT
I'm using it to provide a remote "kill" switch for my child's electric car, so that when she's about to crash or do something daft I can kill the power. The box is all connected up and functioning in that respect.
When the car is not moving the key fob can activate the relays from about 35ft. However when the car is moving the range drops to less than 10ft.
The receiving Aeriel is basically a length of insulated wire wound into a short coil inside the plastic box housing the circuit.
Any ideas what causes the reduction in range of the signal? Could it be some sort of interference from the drive motors?
What "simple" things (if any) could I do to improve it? If I straightened the coil aerial and fed it outside the housing would that make a difference?
Thanks for your help.
Nick.
Nick.
