Express PCB LED Symbol
tracecom
Joined Apr 16, 2010
3,944
Attached is a screen shot of the pictograph that ExpressPCB uses to represent T 1.75 LED's. In their layout tips, they say that a square pad should be used to represent the positive lead in a polarized component. I am confused by what seems to be a contradiction.
The flat side of an LED is (usually) the cathode, which is the negative side, right? And yet they use a square pad to represent the cathode. Or am I wrong as usual? :confused:
mcgyvr
Joined Oct 15, 2009
5,394
It really doesn't matter. Put it on the anode side if you wish. Typically I use a square pad to indicate position 1 of a header/connector,etc...
n1ist
Joined Mar 8, 2009
189
Actually, that's the convention for diodes in general. For parts with numbered pins, the square pad is used for pin 1.
/mike
