Exponential function and equations
Discussion in 'General Electronics Chat' started by vead, Sep 5, 2016.
  1. vead
    Nov 24, 2011
    621
    8
    Hello
    Exponential function that take argument any return value of e raised to power x
    F(t) =e^t
    F(0)=1,f(1)=2.718, f(2)=7.38,f(3)=20....etc
    It can be seen function is raising exponentials. I understand exponentials function. But I am having problem how they relates to electronics. How voltage and current signal represent as exponential function. So I trt to understand, look below example charging current flowing in series RL circuit as exponentials function over time
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I'm not sure what your question is. An exponential function with a negative exponent will asymptotically approach 0 as time goes to ∞. If you subtract an exponential function with a negative exponent from a constant, like 1, then the result will approach 1 as time goes to ∞. An exponential function with a positive exponent represents a system that is unstable and has the potential to destroy itself.
  3. vead
    Nov 24, 2011
    621
    8
    Have you seen the formula in last line? There is formula for current, that flow in RL series circuit. It is exponentials function. I don't understand that formula. I can solve questions but I don't understand concept behind the formula
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    At t=0 the value of the exponential function is 1, and 1 -1 = 0 so that is the value of the current at t=0. At some large value of t the value of the exponential is very nearly equal to 0, and so the value of 1 - ε, where ε is a very small number, is just a little less than 1 which is the current at that very large value of t.
  5. vead
    Nov 24, 2011
    621
    8
    M
    How to derive formula for current that is flowing in circuit
  6. wayneh
    Sep 9, 2010
    12,392
    3,246
    This is trivial if you know calculus and differential equations. Do you?
  7. vead
    Nov 24, 2011
    621
    8
    My attempt
  8. wayneh
    Sep 9, 2010
    12,392
    3,246
    You're close. Can you solve: e - IR - L•dI/dt = 0 for I = ƒ(t)?
    Consider the boundary conditions when the switch opens or closes, when t=0 or t=infinity
    Hint: Separate the dI and I, and dt terms so you can integrate them separately.
  9. vead
    Nov 24, 2011
    621
    8
    What do you mean by e, I think voltage correct. Please confirm
    My mistake small i and capital I are same things
  10. wayneh
    Sep 9, 2010
    12,392
    3,246
    Yes, e or emf. Note my previous hint.
    dI/dt = (V - IR)/L = (V/R - I)/(L/R)
    dI /(I - V/R) = - dt/(L/R)
    Integrate
  11. vead
    Nov 24, 2011
    621
    8
    By taking integration answer is - (R /L) *t
  12. wayneh
    Sep 9, 2010
    12,392
    3,246
    Recheck your last step.
    Then think about what Imax is.
  13. vead
    Nov 24, 2011
    621
    8
    My mistake I=V/R+e^_(R/L) *t ampear
    At t=0
    I(0)=V /R amp
    At t=infinity
    I=V/R
  14. wayneh
    Sep 9, 2010
    12,392
    3,246
    Right, so you can rearrange the result to:
    I(t) = I(0) • [1 -exp(-t•R/L)]
    You can further define the time constant tau as L/R, giving:
    I(t) = I(0) • [1 -exp(-t/tau)]
  15. vead
    Nov 24, 2011
    621
    8
    I am confused,
    We have equations
    I(t) =V/R +e ^-(R /L) *t
    How it become I(t) =I(0).[1-e ^-(R /L)*t]?
  16. wayneh
    Sep 9, 2010
    12,392
    3,246
    My bad. You had an earlier error I missed. I was going to draw this out for you but I found a nice exposition of it online.
    See here.
  17. vead
    Nov 24, 2011
    621
    8
    I looked that is good. Also I have equation for i(t) given in text book. and I can find out voltage across resistor and inductor. Look at attached page
