Exponential form of a Fourier series
Discussion in 'Math' started by amilton542, Nov 27, 2014.
  1. amilton542
    Thread Starter Active Member
    Nov 13, 2010
    494
    64
    Does anyone know why the exponential form of a Fourier series works from - infinity to +infinity?
    I'm using Advanced Engineering Mathematics by Kreyszig but I find his derivations are a bit "arty farty" if that makes sense. I don't like them. He omits too much.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    Your question is ambiguous.
    Are you talking about -∞ to +∞ in the time domain as opposed to 0 to +∞ in the time domain for the typical Laplace transform?
    If so, the reason is that the typical Laplace transform that we usually use is the one-sided Laplace transform and it blows up for t<0. There is the two-sided Laplace transform that works over all time, but it is quite a bit more troublesome to use.
  3. studiot
    Nov 9, 2007
    5,005
    515
    There's no magic about this
    Application of the Euler formulae connecting sin and cos with a complex exponential (did you mention it was complex?) yields
    f(x) = {c_0} + \sum\limits_1^\infty  {\left( {{c_n}{e^{inx}} + {k_n}{e^{ - inx}}} \right)}
    The summation runs from n=1 to n = infinity.
    Put that into the first term in the sum you get all the terms from 1 to infinity.
    Put it into the second and you get all the terms from minus infinity to -1,
    The additional term for n=0 when the summationlimits are changed comes out of the constant before the old summation, which is then absorbed into the new summation.
    If you like you can decompose it thus
    f(x) = \sum\limits_{ - \infty }^{ - 1} {\left( {{c_n}{e^{inx}}} \right)}  + {c_0}{e^{0ix}} + \sum\limits_1^\infty  {\left( {{c_n}{e^{inx}}} \right)}
    since both expressions have the same form these can be combined into a single expression running from minus infinity to plus infinity.
    f(x) = \sum\limits_{ - \infty }^\infty  {{c_n}} {e^{inx}}
    Which is the exponential form you are asking about.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    My apologies -- I thought you were asking about the Fourier transform, not the Fourier series. Studiot gave a good answer.
  5. amilton542
    Nov 13, 2010
    494
    64
    Yeah I get it now. Change the summation limits of the exponential with the negative exponent then it becomes positive. Another thing I was a bit skeptical about was how the latter expression "masks" the constant but I see what you've done now.
    O.K thanks.
