Explosion In Tianjin, China
Discussion in 'Off-Topic' started by Glenn Holland, Aug 14, 2015.
  1. Glenn Holland
    Dec 26, 2014
    359
    114
    According to the news, the explosion in China was caused by a huge warehouse filled with explosives of various types.
    I live 4 blocks from the Golden Gate in San Francisco and there are container ships coming in from the Pacific and headed for the Port Of Oakland. In addition to everything else that's imported into the U.S. from China, I hope the U.S isn't importing explosives too. :eek:
  2. #12
    Nov 30, 2010
    16,665
    7,310
    It's worse than you think. The U.S. actually makes explosives!
  3. Glenn Holland
    Dec 26, 2014
    359
    114
  4. JoeJester
    Apr 26, 2005
    3,393
    1,211
    I guess we will have to have a "bigger" explosion to re-capture the record. Naw. That would lead to an "explosion" race to determine which nation wins the prize for the biggest explosion.
  5. nsaspook
    Aug 27, 2009
    3,009
    2,352
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    Yea.. more pollution floating here from China..
  7. nsaspook
    Aug 27, 2009
    3,009
    2,352
    A toxic stew.
    http://www.reuters.com/article/2015/08/14/us-china-blast-idUSKCN0QH2B220150814
    So then you water it down to make sure it explodes.
    I wonder who will be the new deputy propaganda department head.
  8. atferrari
    Jan 6, 2004
    2,663
    783
    Hola Glenn,
    If that worries you, then, container terminals might be a more valid concern because they have a storage area, unless they deliver them "hook to truck".
    To help you to rest tonight and the forthcoming ones, have you realised that everything coming from overseas comes through the sea? Just to contribute to your peace of mind, please google IMO dangerous goods. I lived with that for 17 years at sea plus these 24 as a surveyor.
    As a Ch. Officer, after taking over in an LPG carrier with vessel loaded, after 48 hours I said to myself: I need to sleep so if this thing blows up, I will not even know that.
    About 2 or 3 years ago, a major carrier issued a worldwide memo warning that some hundreds of containers having been serviced at a certain place entailed a sure risk of explosion when their refrigerating system was opened for servicing...
    Moving inland maybe? Have a good night.
  9. Biff383
    Member
    Jun 6, 2012
    49
    19
    MICHIGAN seems to be a little better now.
  10. nsaspook
    Aug 27, 2009
    3,009
    2,352
    There is no way only 50 people were killed, the place looks like Hiroshima near the explosion.
  11. BR-549
    Sep 22, 2013
    2,168
    416
    Wasn't Hiroshima 20 kiloton? I think the first report I heard said this was 21 kiloton. It will probably go up.
  12. Glenn Holland
    Dec 26, 2014
    359
    114
    I will check the reports again.
    However I recall the total energy yield of this explosion was equal to just 25 tons of TNT and maybe equal to a micro-nuclear device.
    That's 50,000 Lbs. and to visualize this, it's the weight of 2-1/2 city transit buses. The largest bomb using conventional explosives in the U.S. military arsenal is 25,000 Lbs.
  13. nsaspook
    Aug 27, 2009
    3,009
    2,352
    The Chinese government reports say 21 tons (thinking that's on the far low side) but I haven't seen reliable seismic data to verify this.
    http://quarksandcoffee.com/index.ph...was-the-shockwave-from-the-tianjin-explosion/
    We (the military) had a slide-rule and chart to calculate blast-zone damage for tactical nukes using the TNT equivalent so we could be 'safe' from the effects.
    https://www.metabunk.org/attachments/blast-effect-calculation-1-pdf.2578/
  14. Glenn Holland
    Dec 26, 2014
    359
    114
    I'm wondering why the energy yield of a nuclear explosion is not expressed in Joules, Gigawatt-Hours, or simply "Mass Defect".
    If mass defect was used, it could be referenced to the energy equivalent of 1 gram of fissionable/fusible material.
    While comparing the energy a nuclear device to the equivalent amount of conventional explosives is good for explosive purposes, it would be more convenient (at least from the viewpoint of physics) to use something related to the actual energy output.
    Hypatia's Protege likes this.
  15. JoeJester
    Apr 26, 2005
    3,393
    1,211
    12-15 kT was the Hiroshima bomb.
    TNT was the choice of reference. Explosive personnel at the time understood that. If they used another scale, how would they get their point across that to protect your ass, you needed to be further away than anything you've seen before.
    The first thermonuclear device, "Mike", took out Elugelab Island. You can still see the hole left by Mike and another on google earth .... 11°39'57.56"N 162°11'23.52"E
    You can see "Mike" the first multiple megaton explosion, 10.4 megatons ... search for Operation IVY on youtube.
    Sinus23 and nsaspook like this.
  16. Glenn Holland
    Dec 26, 2014
    359
    114
    I was thinking about a practical numerical expression for use in physics rather than one for military use.
    Another brilliant idea of mine goes down in flames -again!!! :(
  17. #12
    Nov 30, 2010
    16,665
    7,310
    I'll help. You tell me the conversion factor for kilotons of TNT to grams of mass and I will use your standard of measurement whenever it is needed in the Chat or Projects Forum.
  18. BR-549
    Sep 22, 2013
    2,168
    416
    Couldn’t we cram 20 kiloton of TNT into a semi trailer? Or equivalent of plastic(bigger bang)?
    That’s not that big. We now have transports that can drop semis, don’t we?
    How much does a tank weigh? We have steerable chutes now. Course I don’t know the 20 kiloton glide time.
    So we could make large clean bombs.
    If we set one off on a salt flat, other than the crater, there wouldn’t be that much damage.
    And if leveling a small town or military installation is necessary, it wouldn’t leave any radiation.
    Surely the military has more than a 10 kiloton conventional weapon.
    JJ......maybe your right. It might be 20 kiloton was the second one.
  19. Glenn Holland
    Dec 26, 2014
    359
    114
    I recall that the largest conventional in the U.S. arsenal contains 25,000 Lbs. of potent explosive.
    That would fit in a tractor trailer, but the housing might make it a lot larger. However it's made, it's got to be small enough to be carried in a B-52 size bomber.
  20. nsaspook
    Aug 27, 2009
    3,009
    2,352
    Or the back of a cargo plane.
    I think the lowest yield for a nuke was 10-tons on a Davy Crockett.
    Proton M, I'm guessing this is equivalent to a few tons of TNT
    They installed the sensors upside down in the rocket. Stuff happens.
    http://www.russianspaceweb.com/proton_glonass49.html
    DerStrom8, Metalmann and JoeJester like this.
