Explanation of Overdrive term?
mcasale
Joined Jul 18, 2011
210
If you are trying to turn on a BJT, and really want the device to go into saturation, you want to drive the BASE with more current than you think you'll need.
For example, if the load on the COLLECTOR requires 100mA, the BASE current needs to be 100mA/BETA, at least. Once in saturation, BJT BETAs go way down. I always assume a minimum BETA of 10, unless the spec sheet gives you a better number.
As always, watch out for total device power dissipation.
