Explanation needed for circuit!!
Discussion in 'General Electronics Chat' started by mechas, Feb 4, 2009.
  1. mechas
    Oct 23, 2008
    Hi guys, can anyone please explain what will be the output for this circuit & its working...! Sorry, but please be as quick as possible as i need it urgently.
    thanks in advance..!
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    It's a clamp circuit. It will offset your input signal downwards by about 3.5 volts., with no small amount of distortion.
    eric
  3. mik3
    Feb 4, 2008
    4,846
    63
    It will clip the output voltage at about +5.7V.
  4. mechas
    Oct 23, 2008
    This is what i came up with 2..but the answer given in the book is
    The explaination given for this answer is that
    Code ( (Unknown Language)):
    1.
    2. V[SIZE="1"]a[/SIZE] = [10kohm/(10+10)] * 5sinwt = 5sinwt
    3.
    4. w = frequency (rad/sec).
    5. V[SIZE="1"]a[/SIZE] is the voltage at the anode of the diode.
    6.
    7. Since maximum voltage at point A may be 5V, hence voltage across the diode always will be less than or equal to zero.
    8.  So it willbe reversed always.
    9.
    I couldnt understand this explaination...is it incorrect or is there some part of the problem that i overlooked??
    Please point out the solution and Thanks for your quick replies, really appreciate it..!
  5. mik3
    Feb 4, 2008
    4,846
    63
    Yes, the book is right. I missed that both resistors are 10K (form a voltage divider) and the maximum output voltage is +-5V. Thus the diode will never conduct.
  6. mechas
    Oct 23, 2008
    Thanks a lot guys for the help & especially mik3...solved the problem for me!!
    cheers :)
