Explaining Thevenin Equivalent?
Discussion in 'Homework Help' started by TripleDeuce, Mar 14, 2011.
  1. TripleDeuce
    Sep 20, 2010
    26
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    VbG=3V
    VaG=2V
    Hence Vba=VbG-VaG=1V
    Looking into terminals ab with the voltage source considered a short and the current source considered an open circuit, one would see a total resistance of 2Ω||2Ω + 1Ω = 2Ω.
    So the equivalent circuit at ab is a 1V source in series with a 2Ω resistor.
    The bottom link is just the ground (G) reference.
  3. Vahe
    Member
    Mar 3, 2011
    75
    9
    Actually, I think the bottom link is not the ground reference. I think the G node disappears when you add the two 1Ω resistors in series.
    Cheers,
    Vahe
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    That's true. The G link is "hidden" in the right hand equivalent circuit.
