explaining circuit
Discussion in 'General Electronics Chat' started by Bill David, Oct 23, 2012.
  1. Bill David
    Oct 23, 2012
    5
    Hi all
    the attached picture shows the internal circuit of an operational amplifier LM324.
    it actually measures the difference of voltage between 2 inputs.
    can anyone of you help me with explaining how does the process of measuring this difference take place ?
    Thank you
  2. kubeek
    Sep 20, 2005
    4,688
    806
  3. electron_prince
    Member
    Sep 19, 2012
    93
    start with differential amplifier.
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    The theory similar like Seesaw.
    You can measure the V,I of the circuit.
    Rc1,Rc2 use 10K. (Rc1-Q1,Rc2-Q2)
    Re1,Re2 use 100Ω. (Re1-Q1,Re2-Q2)
    R1=1K
    Input1 → 22K → VR1M1 → +Vcc
    Input2 → 22K → VR1M2 → +Vcc
    +Vcc → +5V
    -Vee → GND
    VR1M1,VR1M2 - Variable resistor.
    You could adjust the VR1M1, not adjust VR1M2, and measure the following Voltage, and calculating the current.
    Adjust VR1M2, not Adjust VRM1, and measure the following Voltage, and calculating the current.
    Vc2_Q2=
    V_Rc1=
    V_Rc2=
    V_Re1=
    V_Re2=
    V_R1=
    I_Rc1=V_Rc1/10K=
    I_Rc2=V_Rc2/10K=
    I_Re1=V_Re1/100Ω=
    I_Re2=V_Re2/100Ω=
    I_R1=V_R1/1K=
    You can also change the resistors to the other values, and then adjust VR1M1,VR1M2, and do the measuring as above.
    If you want to measure more value, then you can change +Vcc to 9V,12V,15V...30V
  5. ramancini8
    Member
    Jul 18, 2012
    447
    119
    The schematic is not for a lm324 because the transistors are NPN.
  6. kubeek
    Sep 20, 2005
    4,688
    806
    The original schematic is not for anyhting because no opamp is that simple.
