Explain this hum behaviour?
Discussion in 'General Electronics Chat' started by daviddeakin, Aug 19, 2012.
  1. daviddeakin
    Thread Starter Active Member
    Aug 6, 2009
    207
    27
    can anyone explain this hum behavior to me?
    I have a 6V transformer powered from the mains, and attached to one leg is a 68 ohm resistor- that's it, no other connections at all. Now, if I connect my oscilloscope probe as shown, I read the ugly hum voltage shown in the photo. But if I reverse the scope leads I measure no hum at all! How is this possible?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    It isn't hard, the resistor is a shunt resistor, it reflects the current flowing through it.
    Opps, reread your post.
    Don't forget, the scope is grounded though.
  3. kubeek
    Sep 20, 2005
    4,691
    806
    This is probably due to capacitive coupling between the transformer windings.
    There is some current flowing through the transformer to the ground, so one way you are measuring the drop across the resistor and the other way there is no current through the resistor (the current leaves at the first connection) so you measure no voltage.
  4. daviddeakin
    Aug 6, 2009
    207
    27
    Sounds plausible- thanks for the tip!
  5. MrChips
    Oct 2, 2009
    12,648
    3,458
    I tried to duplicate your experiment but did not get the same result.
    In both cases I got no measurable signal.
  6. chrissyp
    Aug 25, 2008
    82
    10
    The scope is picking up the resonance (or feedback whichever you prefer to call it)of the transformer through its own grounding route . Put a 2 pin mains cable into your scope,ie no earth and the hum will not happen.
  7. #12
    Nov 30, 2010
    16,705
    7,355
    68 ohm shunt on the scope input? It takes a pretty good hum field to make a voltage on that. Better check for crusty connections in and around the scope lead.
    I like the answer from kubeek but I also worry about intermittent connections. Probably because my scope is 35 years old.
    Does it quiet down when you unplug the transformer?
  8. daviddeakin
    Aug 6, 2009
    207
    27
    Yes, it is only present when power is applied. I can also turn the level up and down with a variac. I get the same result on both channels of the scope, and with different scope leads, and with the resistor attached to either of the transformer leads.
  9. #12
    Nov 30, 2010
    16,705
    7,355
    That pretty much proves kubeek is right.
  10. crutschow
    Mar 14, 2008
    13,509
    3,385
    I did a rough calculation and it would take about 600pF primary-secondary capacitance to generate the measured output voltage across 68 ohms.
  11. Ron H
    Apr 14, 2005
    7,050
    657
    Does that assume 240V on both sides of the primary, relative to scope ground? One end should be close to ground potential. I believe that would double the capacitance estimate.
  12. crutschow
    Mar 14, 2008
    13,509
    3,385
    I assumed 240V from primary to ground. But, now that you mention it, it's probably 120V to ground from each winding to ground with the two voltages 180° out of phase. That would indeed appear to increase the capacitance estimate since the capacitive currents from the two inputs would tend to cancel.
  13. Ron H
    Apr 14, 2005
    7,050
    657
    This site says that house wiring is 230V, neutral, and ground. Since neutral ≈ 0V relative to ground, then one leg of the primary would be at 230v, the other at 0v. The average voltage across the interwinding capacitance would be ≈115v.
  14. maanga
    Aug 20, 2012
    12
    It is NOT possible to generate a small wave form without a current in a 68 ohm resistor. this resistor will shunt all voltages on the high impedance probe. This must be the residual voltage on the scope itself with high amplification. What is the value (voltage) are you measuring?
  15. MrChips
    Oct 2, 2009
    12,648
    3,458
    The only plausible explanation I can think of is what you think is a 68Ω resistor is not 68Ω at all.
  16. Ron H
    Apr 14, 2005
    7,050
    657
    Sure it can. Kubeek explained it in post #3. Attached is a simulation.
