Explain charge injection in simple terms
Discussion in 'General Electronics Chat' started by bug13, Jun 10, 2013.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys,
    It's me again, I am hope to understand the term Charge Injection, I don't need all the details, I am hoping to get some simple explanation of what cause it, and how to avoid it.
    Please don't link me to academic definition, as you may guess, my brain is no good at processing those(I am not smart).
  2. crutschow
    Mar 14, 2008
    13,497
    3,373
    What is the context for this charge injection? What devices are you concerned about?
  3. bug13
    Feb 13, 2012
    1,213
    38
    say for a MOSFET
  4. crutschow
    Mar 14, 2008
    13,497
    3,373
    Charge injection in MOS devices, when they are used as a switch, is due to the gate capacitance. When the gate voltage is changed to turn the switch on or off the movement of charges in the gate-source and gate-drain capacitance injects charge into or subtracts charge from the conduction channel (depending upon the gate polarity change). This then appears as a spike of voltage in the signal being carried by the MOSFET. Thus to minimize charge injection you want to use MOSFETs with the minimum feasible gate capacitance, which generally means the smallest MOSFET device that still has a low enough ON resistance for the signal being switched.
    bug13 likes this.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    And there are other ways to deal with it, as well.
    As long as the node that the charge is injected onto is isolated, what goes on comes off when the gate is switched the other way. Also, you can have another matched FET placed to pull a comparable amount of charge off the node.
    Another context for charge injection is charge injected into the substrate. Thus charge can then make its way to other circuits and provide a source of crosstalk between them.
    bug13 likes this.
  6. bug13
    Feb 13, 2012
    1,213
    38
    I am not sure if I understand this, can you show me with a circuit please?
  7. crutschow
    Mar 14, 2008
    13,497
    3,373
    CMOS analog switches do that. They use an N-MOSFET and a P-MOSFET in parallel to switch the signal. Since the N-MOSFET and the P-MOSFET use opposite polarity signals to turn on and off, the charge injection from one is cancelled by the opposite charge injection from the other, limited by how well the two gate capacitances match.
    bug13 likes this.
