experiments about corona discharge
Discussion in 'General Electronics Chat' started by antonio07, Apr 17, 2010.
  1. antonio07
    Apr 17, 2010
    hi,
    i have to carry out some experiments about insulating specimens.
    May anyone suggest me how produce the corona discharge in such specimens?
    these specimens are circular, with a radius about 1.58 inch (4 cm)
    thank you.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    "I have to" might suggest some laboratory environment. What are the circumstances you have in terms of equipment and resources, plus the means of controlling the high voltages?
  3. antonio07
    Apr 17, 2010
    you are right: i am an italian student who are doing these experiments for the thesis of the master degree.
    My specimens are nanocomposites with resistivity abot 3*10^12 Ohm*m, the maximum electric field will be about 5MV/m, the specimens have a thickness about 0.1 inch (0.2 mm).
    i have a picoamperometer, a regulated power supply and a shielded chamber.
    excuse me for my broken english.
    thank you
  4. retched
    Dec 5, 2009
    5,201
    313
    Well, that should about cover it. :)
    I am interested.. What types of materials are you using for coronal discharge at such small power levels?
  5. antonio07
    Apr 17, 2010
    the voltage will be 5MegaVolt/m, the corona discharge shoud occur in the nanocomposites...it should simulate the effect of ageing...
  6. retched
    Dec 5, 2009
    5,201
    313
    Sorry, I read it as 5 millivolt... Geez.. I was off by a few zeros... and a decimal point.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    So you have a power supply capable of producing the voltages you need?
    Are you doing these experiments at 15PSI, or in a vacuum?
  8. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
