experiment Project
Discussion in 'The Projects Forum' started by scabbers, Oct 4, 2013.
  1. scabbers
    Oct 4, 2013
    Morning all!
    i am doing an experiment to prove that certain vending machine/games can not be won in particular ones involving timing.
    so my project is to build a device that can depress a button for a set amount of time...
    the timing needs to be adjustable preferable down to the 1/100th of a second but im sure 1/10th will surfice...
    so i have no problem building the rig and depressing action and battery suply etc etc but working with the adjustable timing is beyond me...
    preferable i would have a digital display that informs me of the timing i have selected for the process...
    all help is appreciated!! and i will post the results of the experiment once completed !!
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Seconds? Hours? ....?
    Do you mean generate a pulse?
    In that case you'll probably need a microcontroller.
