hiii
the RV-MDK assembler is not able to run assembly code through the C preprocessor, the relevant contents of bl_config.h need to be converted to assembly format for inclusion into the RV-MDK startup code.
iam using uv4 ,luminary cm3 uc.
wen i complie the code the following err is displays:
bt_config.c(46): error: #65: expected a ";"
is pointed to be follwing code :
// Define an assembler symbol for the stack size.
_STACK_SIZE equ STACK_SIZE
// Define an assembler symbol for the application starting address.
_APP_START_ADDRESS equ APP_START_ADDRESS
// Define an assembler symbol for the application vector table address.
_VTABLE_START_ADDRESS equ VTABLE_START_ADDRESS
