Expansion Of Mux?????
Discussion in 'Homework Help' started by dogar sahab, May 25, 2008.
  1. dogar sahab
    Thread Starter Active Member
    Mar 15, 2008
    116
    Please help me out im solving the question
    I have to construct quad 9-1- line MUX with four single 8-1- line MUX and one quadruple 2-1- line MUX.The MUX should be interconnected and inputs labelled so that the selection codes 0000 through 1000 can be directly applied to the MUX selection inputs without added logic.
    I dont know what I should do with the unused inputs while constructing larger MUX from smaller MUX??
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Just ignore the inputs that aren't used. The 2 -1 mux drives the disable lines of the 8 - 1 mux, and the 2-1 mux input becomes part of the binary number.
  3. dogar sahab
    Mar 15, 2008
    116
    OKAY..It means that if I have to cnstruct 15-1 line MUX from two 8-1 line MUX,then I should ignore the unused input(16th input) of the second MUX.
    Is it right if I assert this unused input into the 3-input-OR gate which also contains the outputs coming from two(8-1 line MUX)..???
