expanding 2D matrix by fraction
Discussion in 'General Electronics Chat' started by aamirali, Jul 24, 2013.
  1. aamirali
    Feb 2, 2012
    415
    I have image store in 2D matrix. i.e for each address of TFT I have which bit is set & which is zero.
    Consider image as black & white, 1 means pixel on & 0 means pixels off. So i have all the values in 2D matrix.
    Now I have to expand this array while printing, this is expansion is both on x & y axis. Like on x axis it should be 1.25 times the original & on y it should be 1.5 times.
    How to do that in best way
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    There are a number of ways to do it and various methods produce better quality results for different types of images. So it is very much a function of the type of image is being represented and what type of information is most important to retain in the scaled up image.
  3. aamirali
    Feb 2, 2012
    415
    I have to print small graph/values/text only. Even if some bits are lost (but not many) it won't affect
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    The quickest and easiest way (and the one that will likely give you the poorest results, but if they are good enough, they are good enough) would to simply repeat every 4th column and every other row. So you might try that and see if it is acceptable.
  5. aamirali
    Feb 2, 2012
    415
    that would not work as I have to show graph. which is part of image.
    Can u plz point some links/another algo
  6. WBahn
    Mar 31, 2012
    18,085
    4,917
    Why would that not work? Try it and see. What does it do that is unacceptable? Often time the way to find a suitable approach is to try approaches that you expect to be unsuitable and examine them closely to find out why they are unsuitable.
    Remember, this is YOUR problem. Don't expect others to do all of your work for you.
  7. MrChips
    Oct 2, 2009
    12,625
    3,451
    What computer platform and language are you using?
    Matlab has functions to do this.
  8. sirch2
    Jan 21, 2013
    1,008
    351
    If all you have is a mono-chrome bitmap then short of line-tracing the graph to create a vector representation of it, all you can sensibly do is repeat the previous pixel.
    It would be better to alter whatever creates the graph to give you the correct image resolution in the first place.
