Exist an integrated circuit with this truth table?
Discussion in 'General Electronics Chat' started by Volvagia, Sep 2, 2014.
  1. Volvagia
    Jul 22, 2014
    6
    Hello there.
    I'm relatively new to (digital) circuits, so I search an IC with the following truth table best in the 74xx line:
    Code (Text):
    1.
    2. In In In In Out
    3. 0  0  0  0  x (maybe Z)
    4. 1  x  x  x  a
    5. 0  1  x  x  b
    6. 0  0  1  x  c
    7. 0  0  0  1  d
    8.
    Where 1 coult be 0 and vice versa, x = don't cares, Z = high impedance and a != b != c != d.
    I'll create a priority system. When the first component "activate" the line, the circuit should do something, no matter the other components. When the second compontent activate the line and the first don't do it, the circuit should do something other, no matter component 2 and 3 do it.
    I won't build this using simple logic gates, because this get big.
    Thank you
  2. kubeek
    Sep 20, 2005
    4,687
    805
    How about 74147 or 74148? Just searching for a priority encoder and 7400 series
    What do you need this for? Maybe getting some programable logic device might be a better idea.
  3. Volvagia
    Jul 22, 2014
    6
    Thank you :)
    I wan't try design a shared bus. When the bus is free and any component want to send, the component with the highest priority get the permission to send.
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    Using 74147 or 74148 and CD4051.
    147,148 are the decoder for highest priority to get the permission, and to choose the cd4051 to open the gate to get the data from d0 to d7.
  5. Volvagia
    Jul 22, 2014
    6
    Why the CD4051?
    I through about D-Flipflops with Tristate output, e. g. the 74173. When the component get the permission, it will send the adress of the target component and the data on a edge of the bus clock. The target component read the data from the bus on the opposite clock edge (Send on the rising and read on the falling or send on the falling and read on the rising). The reading component prepare the answer and request a send. (Or maybe store the incoming data on a Last-in-last-out-queue etc. if he has no time to answer or must answer to another request first.)
    But it think i'm thinking to complex. ^^
    Here I would need many things. 1 data line for send request, 1 for send permission, 1 for the bus clock, 3 for 8 possible target components, the shared data lines self and a LILO-Queue on each component, because 2 or more higher priority components could send to the same target before it could send a answer or handle a request.
    Thank you
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    A field programmable ROM would take just one.
  7. crutschow
    Mar 14, 2008
    13,475
    3,361
    What do a, b, c, d represent in your truth table?
    What is (!)?
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
  9. kubeek
    Sep 20, 2005
    4,687
    805
    He means actual priority, such that when devices A and B request bus at the same time, the one with higher priority will be granted bus arbitration.
    Another possibility to do the arbitration with minimal parats count would be along the ways CAN works, that is open collector bus. The device with lowest address will win arbitration, as it will pull all the arbitration lines low. All other devices will sense that the bus contains a different address than their own and will back off and wait.
  10. ScottWang
    Aug 23, 2012
    4,925
    777
    The CD4051 offering the easy way to get the input data from 1 of 8, if you have to using the data and clock and have a sequence then maybe you need to use the 74LS173 or you can attach your circuit and labeling the input and output infos.
  11. Volvagia
    Jul 22, 2014
    6
    ok, thank you :)
