http://paste.ubuntu.com/7037458/
Dear all,
I have simple code ,I wanted to execute LCD_call function once from main loop.Here i am trying to set menu. i have 1 windows label1: Display and Set_parameter window. up and down button to navigte menu under each screen , right to change MEnu window. LEFT key to exit.
problem : When LCD _call is called , Inside loop it execute the display paramter and all. As per me it must stay in wherever the displayed window stopped unless any key changed.But here after every 6s display menu changes to loop(). Is there any way to execute once
Dear all,
Rich (BB code):
void loop()
int button;
while(( button = read_LCD_buttons()) != btnLEFT)
lcd_call();
void lcd_call()
lcdClear();
lcd.print("MENU DISPLAY:");
// button = read_LCD_buttons();
while (menuOption <= menuOptions)
/*if (button == btnRIGHT)
//timedBeep(shortBeep,1);
menuOption=menuOption+1;
Serial.print("menuOption:");
Serial.println(menuOption);
else
menuOption=1;
//button = read_LCD_buttons();
switch(menuOption)
case 1:
lcdClear();
lcd.print("DISPLAY PARAMETER");
timedBeep(beep,1);
delay(300);
if((button = read_LCD_buttons()) != btnRIGHT)
goto LABEL1;
else
goto SETPARAMETER;
LABEL1:
while((button = read_LCD_buttons()) != btnRIGHT)
int DS_Counter;
Serial.println(button);
DS_Counter=Display_selection();
Serial.print("DS_Counter:");
Serial.println(DS_Counter);
switch(DS_Counter)
case 1:
lcd.setCursor(0,0);
digitalClockDisplay();
break;
case 2:
lcd.setCursor(0,0);
Display_angle();
break;
case 3:
lcd.setCursor(0,0);
Display_coordinate();
break;
case 4:
lcd.setCursor(0,0);
Display_Wind();
break;
case 5:
DS_Counter=1;
break;
case 2:
lcdClear();
lcd.print("SET PARAMETER");
timedBeep(beep,1);
delay(150);
// delay(1000);
goto SETPARAMETER;
else
goto LABEL;
SETPARAMETER:
// while ( (button = read_LCD_buttons()) != btnSELECT)
while((button = read_LCD_buttons()) != btnLEFT)
// int Set_Counter=0;
Set_Counter=Select_section();
Serial.print("Set_Counter:");
Serial.println(Set_Counter);
switch(Set_Counter)
case 1:
if(Set_lat_Flag==0)
set_latitude();
//goto COUNTER;
else
break;
case 2:
if(Set_long_Flag==0 )
set_longitude();
//goto COUNTER;
else
break;
case 3:
if(Set_Track_flag==0)
set_trackertime();
else
// goto COUNTER;
break;
case 4:
if( Set_DT_Flag==0)
Serial.print("Set_DT_Flag:");
Serial.println(Set_DT_Flag);
setDateTime();
else
Set_Counter=0;
Print_Date();
Print_Time();
//goto COUNTER;
break;
case 5:
Set_Counter=0;
Set_flag=0;
Set_DT_Flag=0;
Set_lat_Flag=0;
Set_long_Flag=0;
Set_Track_flag=0;
goto LABEL;
break;
goto LABEL;
//Set_Counter=Select_section();
//menuOption++;
//menuOption=Menu_counter(); //break;//menuOption=Menu_counter();break;
LABEL:
case 3:
menuOption=0;
lcd.begin(16,2);
lcd.setCursor(0,0);
lcd.print("EXIT WINDOW");
timedBeep(beep,1);
//delay(300);
//delay(1000);
//goto SETPARAMETER;
else
goto LABEL1;
menuOption=0;
break;
else
menuOption;
//return 1;
