.exe to matlab
Discussion in 'Programmer's Corner' started by tojeena, Nov 11, 2011.
  1. tojeena
    Thread Starter Active Member
    May 2, 2009
    118
    I want to know whether an .exe file can be converted to matlab code ?
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    An .exe file is most times a compiled for a specific processor.
    You will need to know for what processor the file is made.
    If you know that you can "decompile" it using a dissasembler to assembly language.
    Bertus
  3. MrChips
    Oct 2, 2009
    12,624
    3,451
    The simple answer is no.
  4. tojeena
    May 2, 2009
    118
    How will i extract the source code from the .exe file
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    It cannot be done.
  6. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    It will be VERY difficult to revive the source code from an .exe file.
    It all depends on the type of processor and if there are other files used by this .exe file.
    The best you will gat is a large assembly listing.
    Bertus
  7. samin
    Member
    Oct 14, 2011
    32
    6
    Try using the function SYSTEM.
    Code ( (Unknown Language)):
    1. system('Your.EXE')
  8. tojeena
    May 2, 2009
    118
    I didnt understand what u have meant.I have to get matlab code fro this attached file.. Please help me..
  9. kubeek
    Sep 20, 2005
    4,687
    805
    If you like stepping through tens of thousands of lines of assembler, then disassemble it.
    Otherwise you are more likely to find the author and make him send you the source files than to disassemble it to anythig useful.
  10. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Then he will need a program to convert the original source to Matlab. Listen very carefully -- you are the only person on the planet who has the time, patience, and motivation to do the job manually for this one-off project. Further you are the only person on the plant who has the capability to write the piece of software you are requesting. Time is a-wasting so you better get started.
  11. MrChips
    Oct 2, 2009
    12,624
    3,451
    Hee, hee.:rolleyes: OP has deaf ears. My answer was "no" back at post #3.
  12. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Did "NO" -- even "Hell No!" ever stop the HHO or free energy crowd. Every field of human endeavor has its myth chasers. Here is yet another "tinaja"
    http://www.tinaja.com/
    Note particularly the exciting field of Magic Sinewaves.
