I think the battery polarity are connected where they are supposed to be.positive and negative connected wher they are supposed to be.
Is it possible to build breathing Led like this, using 555 IC but without a transistor?Here is my entry into the Breathing LED contest. Note that in my circuit, unlike the ones posted all over the web, the LED current goes completely to zero.
Only by building a two 555 circuit, where one 555 modulates the pwm duty cycle of the other. In the circuit I posted, the transistor is used as a current amplifier to modulate the LED current directly.Is it possible to build breathing Led like this, using 555 IC but without a transistor?
I can get the LED breathing without transistor but the circuit needs a large capacitor (50000 uF).Only by building a two 555 circuit, where one 555 modulates the pwm duty cycle of the other. In the circuit I posted, the transistor is used as a current amplifier to modulate the LED current directly.
What is the function of R3?Here is my entry into the Breathing LED contest. Note that in my circuit, unlike the ones posted all over the web, the LED current goes completely to zero.
R3 creates the short time when the Red trace is zero (the LED is completely off, passing no current). Without it, the LED dims, but stays on throughout the cycle. My circuit (with the LED in the collector of the transistor) is independent of the Vf of the LED (2V for red, 3.3V for blue or white).What is the function of R3?
by Jake Hertz
by Jake Hertz
by Duane Benson
by Jake Hertz
