Excessive power consumption
Discussion in 'The Projects Forum' started by kelly.jr., Mar 5, 2015.
  1. kelly.jr.
    Mar 5, 2015
    17
    Hi, I am new to electronics. I've been working on this Pulsating LED Project of mine. I use Proteus to design the circuit. I've been wondering what is making the circuit consuming so much power ( it's +63.0 Kw). Thanks for your help.
  2. kdcouture200
    Member
    May 22, 2010
    17
    I would guess that the reason you are getting a reading of 63.0 KW is because the power meter is in a closed loop with the battery only and not the rest of your circuit. so with the resistance of the meter being so small a large current is going to form causing a large power reading.
  3. MrChips
    Oct 2, 2009
    12,623
    3,451
    63kW :eek:
    That's about 50 times what my whole house consumes.
    That is because your wattmeter is shorting the battery.
    Your circuit takes about 100mA @ 14V = 1.4W
    kdcouture200 likes this.
  4. kelly.jr.
    Mar 5, 2015
    17
    I just re check my circuit on proteus. I think I wire the Wattmeter just right.
  5. kelly.jr.
    Mar 5, 2015
    17
    Then why do the Ammeter on the VCC read +MAX?
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    Don't think so. Try Again.
  7. MikeML
    Oct 2, 2009
    5,450
    1,066
    Besides, that is a very complicated 555 multivibrator circuit. The LED driving can be greatly simplified. The 555 can drive ~200mA with no buffering...
    Here is a LTSpice sim of the running circuit, greatly simplified. Note that LTSpice shows us all we need to know (node voltages, branch currents, power dissipated in each element) without having to wire in the stupid little instruments into the schematic, which make it much less readable...
    I show the voltage at the timing network V(c1) red trace V.
    I show the battery current I(V2) green trace mA.
    I show the power delivered by the battery violet trace W.
    All of those are added to the plot just by placing the mouse cursor over the component on the schematic after the sim is run.
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    your 555 is drawing max current, either it is bad or the connections to it are shorted.
  9. kdcouture200
    Member
    May 22, 2010
    17
    And your Watt meter is connected incorrectly.
  10. alfacliff
    Dec 13, 2013
    2,449
    428
    becasue if the 555 is hsorted, the cureent will be max. and the voltmeter will read max because it isnt real, with the limitations on the power supply.
  11. kelly.jr.
    Mar 5, 2015
    17
    I am new to electronics and the simulator. I am currently using proteus. I will give LTSpice a try.
    Your circuit doesn't make the Leds fade in fade out (breathing). I want the graph look like this.
  12. kelly.jr.
    Mar 5, 2015
    17
    I think there's something wrong with proteus on my PC. Because when I simulate MikeML circuit, I still get the same result from the Ammeter (which reads MAX) led2-page-001[1].jpg
  13. alfacliff
    Dec 13, 2013
    2,449
    428
    since the 555 timer and a 4.7k resistor are the only things connected to the 14 volt supply, what is the scaling of the ampmeter? neither should draw very much current. how many amps is the meter rated in ypur program?
  14. kelly.jr.
    Mar 5, 2015
    17
    The scaling (Display Range) is in Amps. When I use probe It reads 9000. see image below ledd.png
  15. MikeML
    Oct 2, 2009
    5,450
    1,066
    I think the Proteus 555 model is at fault (model error).
    I now understand about the "breathing"; I missed that.
    A minor question about the simplified circuit: Why do place D10 there? It is not needed, and only "wastes" 0.6V that would otherwise contribute to LED current. Note that You now correctly have a current-limiting resistor in series with each group of LEDs.
  16. kelly.jr.
    Mar 5, 2015
    17
    I use the diode D10 to prevent current from capacitor C3 flowing towards the Output (Q). I try to made the leds fade in fade out but the graph is still too steep. leddw.png
  17. alfacliff
    Dec 13, 2013
    2,449
    428
    is the battery the correct polarity?
  18. kelly.jr.
    Mar 5, 2015
    17
    Can I get the graph to look like this without using a transistor?
  19. kelly.jr.
    Mar 5, 2015
    17
    what do you mean by "the correct polarity"?
  20. alfacliff
    Dec 13, 2013
    2,449
    428
    positive and negative connected wher they are supposed to be.
