Exception in thread main java.lang.NullPointerException
Ben_C
Joined Oct 19, 2010
65
Hi im getting 2 errors when im trying to run my comman line arguments.. Its giving me the errors:
Exception in thread "main" java.lang.NullPointerException
at MTBFCalculator.<init>(MTBFTester.java:37)
at MTBFTester.main(MTBFTester.java:7)
Rich (BB code):
public class MTBFTester
        public static void main (String [] args)
        usage(args);
        MTBFCalculator calc = new MTBFCalculator(args);
        calc.getMTBF();
        private static void usage(String [] test)
        if (test.length<2)
        System.out.println("usage: java MTBFTester <1st value> <2nd
value> ...");
//This is the other class
class MTBFCalculator
//fields
        String [] argsArray;
        double [] doublesArray;
//constructor
        public MTBFCalculator(String [] data)
        for(int i=0; i<data.length; i++)
        argsArray  = data ;
        doublesArray = new double[argsArray.length];
//method
        public void getMTBF()
        for(int i=0; i<argsArray.length; i++)
        doublesArray = Double.parseDouble(argsArray);
        if (doublesArray < 1)
        System.out.println("zero or negative values are not accepted");
                double testMTBF = 0;
                double MTBF = 0;
                for(int i=0; i<doublesArray.length; i++)
                testMTBF = testMTBF + 1/doublesArray;
                MTBF = 1/testMTBF;
                System.out.println("" + MTBF);
In cmd im copiling it then on the next command line im passing numeric values but get the errors.
Anybody help it needs to be handed in in like 15 hours :p
