Excel Match/Lookup Programming
Discussion in 'Programmer's Corner' started by SigmaCeq, Jul 30, 2009.
  1. SigmaCeq
    Jul 30, 2009
    19
    Sorry I couldn't find a better forum for this! I am trying to find the row where two values occur in separate columns (ie, I need the find the row where 1 is in column B and 3 is in column C, specifically). Is there a way to do this using the regular MATCH, LOOKUP, etc. functions?
    Thank you!
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    Yes...I believe HLOOKUP is the function you're looking for. See the Help files for exact syntax
    Eric
  3. SigmaCeq
    Jul 30, 2009
    19
    I tried and I don't think it will work for me. Thanks though!
    I guess I should be more specific about my table; I have a spreadsheet with over 65,000 rows and columns up to letter N. In column B I have a set of numbers with most of the values occuring more than once in the column. In column D I have a separate set of numbers that also occur multiple times. I need to find the first instance where the number 220 appears in column B and the number 2 occurs in column D in the same row.
    I've looked pretty much everywhere and have not successfully found a way to do this. :eek: Personally I am starting to doubt it exists!
  4. Mass
    Member
    Apr 9, 2009
    26
    I don't know how to do it using functions.
    Is writing a excel macro an acceptable solution here?
  5. SigmaCeq
    Jul 30, 2009
    19
    It could be; I don't know how to write macros but it seems it may be time for me to learn. Any pointers?
  6. Mass
    Member
    Apr 9, 2009
    26
    Here's a macro that I got working...I needed to brush up anyway:p
    The code is bulky and might not be proper, but it works. I tried to make it easy to follow by using descriptive variables.
    Copy the code like this...
    In Excel, go to the Tools menu/Macro/Visual Basic Editor.
    Right click on VBAProject(filename.xls). Select Insert/Module.
    Copy the code below into the editor and close the window.
    To run the macro, go to Tools/Macro/Macros...(with the play icon), select the macro and hit Run. That's it - hope it works.
    EDIT - You may want to comment out the 4 lines "Cells(x, y) = SearchColumn(n)" because it will write into cells A1, A2, B1, and B2. I forgot to remove those lines before I posted.
    Sub SearchTwoColumns()
    Dim QuitSearch As Boolean
    Dim ReceivedGoodInput1 As Boolean
    Dim ReceivedGoodInput2 As Boolean
    Dim ReceivedGoodInput3 As Boolean
    Dim ReceivedGoodInput4 As Boolean
    Dim SearchColumn1
    Dim SearchColumn2
    Dim SearchValue1
    Dim SearchValue2
    Dim FoundInput1 As Boolean
    Dim FoundInput2 As Boolean
    Dim ActiveRow
    Dim ActiveValue1
    Dim ActiveValue2
    While QuitSearch = False
    ReceivedGoodInput1 = False
    While ReceivedGoodInput1 = False
    SearchColumn1 = InputBox("Enter search column 1 (integer)")
    If SearchColumn1 = "" Then End
    Cells(1, 1) = SearchColumn1
    If IsNumeric(SearchColumn1) Then
    SearchColumn1 = Val(SearchColumn1)
    If SearchColumn1 = Int(SearchColumn1) Then
    ReceivedGoodInput1 = True
    End If
    End If
    Wend
    ReceivedGoodInput2 = False
    While ReceivedGoodInput2 = False
    SearchColumn2 = InputBox("Enter search column 2 (integer)")
    If SearchColumn2 = "" Then End
    Cells(1, 2) = SearchColumn2
    If IsNumeric(SearchColumn2) = True Then
    SearchColumn2 = Val(SearchColumn2)
    If SearchColumn2 = Int(SearchColumn2) Then
    ReceivedGoodInput2 = True
    End If
    End If
    Wend
    ReceivedGoodInput3 = False
    While ReceivedGoodInput3 = False
    SearchValue1 = InputBox("Enter search value 1 (numeric)")
    If SearchValue1 = "" Then End
    Cells(2, 1) = SearchValue1
    If IsNumeric(SearchValue1) = True Then
    SearchValue1 = Val(SearchValue1)
    ReceivedGoodInput3 = True
    End If
    Wend
    ReceivedGoodInput4 = False
    While ReceivedGoodInput4 = False
    SearchValue2 = InputBox("Enter search value 2 (numeric)")
    If SearchValue2 = "" Then End
    Cells(2, 2) = SearchValue2
    If IsNumeric(SearchValue2) = True Then
    SearchValue2 = Val(SearchValue2)
    ReceivedGoodInput4 = True
    End If
    Wend
    ActiveValue1 = " "
    ActiveValue2 = " "
    ActiveRow = 1
    FoundInput1 = False
    FoundInput2 = False
    While FoundInput2 = False
    While FoundInput1 = False
    ActiveValue1 = Cells(ActiveRow, SearchColumn1)
    If ActiveValue1 = SearchValue1 Then
    FoundInput1 = True
    ActiveValue2 = Cells(ActiveRow, SearchColumn2)
    If ActiveValue2 = SearchValue2 Then
    FoundInput2 = True
    Else
    FoundInput1 = False
    FoundInput2 = False
    ActiveRow = ActiveRow + 1
    End If
    Else
    If ActiveRow = 65537 Then
    MsgBox ("End of Excel file reached without finding match")
    End
    End If
    End If
    Wend
    Wend
    MsgBox ("Search terms found on row " & ActiveRow)
    If MsgBox("Search again?", vbYesNo) = vbNo Then QuitSearch = True
    Wend
    End Sub
  7. eblc1388
    Nov 28, 2008
    1,542
    102
    This is another way to do that without macro or VBA programming, and it is also easy to change the selection criteria.
    However, the result is visual only so you will have to resort to marco or programming if you want the result as data.
    First Select your range of data, then apply conditional formatting. Put your requirement in the formula. The required data will be then highlighted in color of your choice after you pressed OK.
  8. SigmaCeq
    Jul 30, 2009
    19
    Mass, thank you SO much for your help! The program didn't work exactly how I needed it to, but it's very close so I think I'll be able to edit it (I'm getting a VBA book from the library today... :p). Thank you again!
