Excel file read and manipulate - Matlab
Discussion in 'Programmer's Corner' started by Judas543, Apr 24, 2010.
  1. Judas543
    Jan 26, 2010
    60
    Before I post something about this:
    does anyone know how to read an excel file with matlab and manipulate it?
    I know how to open it and put it in different categories:
    [num txt raw] = xlsread('c:\matches.xls')
    NEED HELP ON THESE THOUGH:
    Count the number of entries that have one blank field
    Copy these entries in a new array that you display in order to review and verify the errors
    Finally you decide to remove these defective entries from your array (for which one field was left blank) by
    copying only the valid entries to a new array, which is going to be your working database
    http://www.sendspace.com/file/q1dp3j - excel file .xls
  2. retched
    Dec 5, 2009
    5,201
    313
    Does the file have to be saved as an Excel file?
    Can you save it as a comma delimited format, then import the data?
  3. Judas543
    Jan 26, 2010
    60
    i believe it has to be saved as an excel file
  4. Judas543
    Jan 26, 2010
    60
    actually maybe i can copy and paste into a text file and read it from there?
  5. johndoe45
    Member
    Jan 30, 2010
    364
    you can choose save as text file like retched said from excel
    than comma delimit it.
    open text with matlab
    in matlab
    load filename.txt
    that is it. then just put filename(row numbers,column numbers)
    for example i want all data in column 1
    matlab syntax
    filename:),1)
  6. Ghar
    Mar 8, 2010
    655
    72
    What's the problem with xlsread? It's pretty convenient...
  7. retched
    Dec 5, 2009
    5,201
    313
    Aww, thats too easy. :rolleyes:
