Example question
Discussion in 'Homework Help' started by jaymo3141, Feb 21, 2014.
  1. jaymo3141
    Feb 16, 2014
    8
    Can someone explain why i1 doesn't lead i3 by 345 degrees?
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    Try drawing the three currents as vectors on a polar plot.
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    First, get all three into the same form, namely
    i_n(t) = I_N cos(ωt + θ_n)
    Then determining how much one leads another becomes trivial.
  4. screen1988
    Member
    Mar 7, 2013
    310
    In i_n(t) = I_N sin(ωt + θ_n) what is the range of θ_n?
    -180 degrees to 180 degrees or 0 to 360 degrees?
    I got two different results with the question i1(t) leads i3(t).
    If θ_n is from -180 to 180 degrees then i1(t) leads i3(t) by 165 degrees.
    If θ_n is from 0 to 360 degrees then i1(t) leads i3(t) by -195 degrees.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    It shouldn't matter what range you choose. Either way, you may need to normalize the answer, but the answers should be the same modulo 360°.
    screen1988 likes this.
  6. screen1988
    Member
    Mar 7, 2013
    310
    I realise I made a mistake. The first case is 165 degrees and the second is -195 degrees.
    And as you said both are correct. There is an infinite number of the correct answers here?
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    Yes, though common practice is to reduce it to less than one complete revolution in either direction and to normally restrict even that to a total range of just one revolution overall.
