example c code pic16f877 in compare mode
Discussion in 'Embedded Systems and Microcontrollers' started by waseem sumer, Mar 11, 2008.
  1. waseem sumer
    Mar 11, 2008
    hi
    i want to programe timer of pic16f877 to generate pulses using compare mode.i am a bigenner so that i need an c code examples.
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I doubt someone will just give you code without any input; I may be wrong.
    Other than suggesting a Google search for the said codes then I think you may be out of luck. You may find better advice is forthcoming if you want help in writing your own.
    Dave
