Exam Tomorrow!
Discussion in 'Homework Help' started by mikewilliams, Nov 9, 2008.
  1. mikewilliams
    Nov 4, 2008
    10
    Hi all I am studying for my exam, and I am looking at different problems, that will be of similarity to the questions tomorrow. I am stuck on how to approach these two however. If you could help me out quickly that would be great as my exam is tomorrow!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Both are way too small to read.
  3. mikewilliams
    Nov 4, 2008
    10
    beenthere, I think when you open them you can click on it with the magnifying glass and then they are full size. If that doesn't work for you I will try to repost.
  4. veritas
    Feb 7, 2008
    167
    I am unable to read the first image.
    For the second problem, you can think of part (a) as being two different independent steps:
    1) Find f1(a, b) such that f1 = 1 if a < b
    2) Find f2(a, b) such that f2 = 1 if a = b
    What questions do you have about these two steps?
  5. veritas
    Feb 7, 2008
    167
    You can define the function by the truth-table
  6. mikewilliams
    Nov 4, 2008
    10
    hi veritas,
    I have figured out that F1 = A'B and F2 = A'B' + AB and I have drawn that implementation. i think what i am having trouble with is part b and c. Do G1 and G2 just follow F1 and F2? I dont believe so but I am not seeing how to solve these.
    Also I will work on reposting problem #1
  7. mikewilliams
    Nov 4, 2008
    10
    ok i have made them word attachments, you should be able to read both now.
  8. veritas
    Feb 7, 2008
    167
    G1 will have 4 inputs: f1_0, f2_0, f1_1, and f2_1, where '_n' is subscript bit.
    One or more of those inputs may simplify away, but start by using all of them.
    The same is true for G2
  9. mikewilliams
    Nov 4, 2008
    10
    any ideas on the other problem?
