exam question about voltmeters and their loading effect on a circuit
Discussion in 'Homework Help' started by bart3b, Jun 12, 2009.
  1. bart3b
    Jun 12, 2009
    I'm half way through dc circuits class and have come to a roadblock, the subject deals with voltmeters and their loading effect.
    The question is: A 15V battery connected in series with a 1kohm resistor is tested with a 20000 ohms per volt voltmeter at the 20V range. What does the circuit measure?
    I'm looking for the formula or combination of formulas needed to solve this. If you can help, thanks.
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Hint: What is the voltmeter measuring?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What is the input resistance of the meter on that scale?
  4. JoeJester
    Apr 26, 2005
    3,402
    1,226
    20000 ohms per volt sensitivity is a 50 uA meter.
  5. bart3b
    Jun 12, 2009
    Meter is measuring voltage in circuit, input R in meter is 400k ohms
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    So far, so good. What do you know about resistors in parallel?
  7. bart3b
    Jun 12, 2009
    Voltage is equal across all components. Total current equals the sum of individual branch currents. Total R equals total voltage divided by total current and total resistance is always less than individual branch resistors.
