Exam Help
Discussion in 'Physics' started by Hello, Dec 26, 2008.
  1. Hello
    Thread Starter Active Member
    Dec 18, 2008
    82
    Can you please have look at the attached file.
    I am having difficulty with Q6 part (v), not sure how to go about it!
    Torque constant, Kt = 0.8
    Back e.m.f constant, Ke = 1.25
    Any help is greatly appreciated.
  2. mik3
    Feb 4, 2008
    4,846
    63
    You know Ke, thus
    The voltage developed across the motor terminals, without the 5 ohm resistor connected, is
    E=Ke*ω
    You know Ke and ω thus you can calculate E (which is actually the back EMF when it is working as a motor).
    The armature resistance is 5 ohms and the load resistance (connected on the motor terminals) is also 5 ohms. Thus the total resistance is 10 ohms. Thus the current through the armature and the load resistance is :
    I=E/10
    Thus the power dissipated in the load is:
    P=(I^2)*5
    Assuming no losses, the torque is:
    T=P/ω
  3. Hello
    Dec 18, 2008
    82
    Thanks for your help, very well explained.
  4. Hello
    Dec 18, 2008
    82
    Im not very sure what 'load resistance' is ?
    If possible could you go to a bit more detail.
  5. mik3
    Feb 4, 2008
    4,846
    63
    The load resistance is just a resistor, 5 ohms in this case, which is connected across the terminals of the motor.
  6. Hello
    Dec 18, 2008
    82
    Thanks, great help!
