exact positioning of laser beam based on eye movement analysis
Discussion in 'The Projects Forum' started by kalaivendhan, Dec 29, 2013.
  1. kalaivendhan
    Dec 29, 2013
    6
    hi friends,this is my first post.
    i'm going to do my final year project based on eye movement analysis using matlab.
    i need interface a hardware material holding up laser with the matlab software and it should move also based on my head movements. can you give any suggestions for me to start and finish it well...:)
  2. wayneh
    Sep 9, 2010
    12,374
    3,226
    So you want to aim a laser based on a person's eye position? (As opposed to using a laser to determine eye position, which sounds dangerous.)
  3. djsfantasi
    Apr 11, 2010
    2,900
    874
    How are you determining eye movement?
    Where will laser be mounted?
    Head movement could be determined by accelerometer.
  4. wayneh
    Sep 9, 2010
    12,374
    3,226
    I don't think that's entirely true. An accelerometer can't determine rotation in the horizontal plane (yaw, on an airplane). Motion, yes, but not absolute position. I think.
    But anyway I think the OP wants to follow only the eye position, not the head position. Hard to tell.
  5. djsfantasi
    Apr 11, 2010
    2,900
    874
    In his first post he states "and also based on my head movements". Hence, the accelerometer should detect movement. I agree it wouldn't detect absolute position but relative position could be tracked in software.
  6. kalaivendhan
    Dec 29, 2013
    6
    our eye movement is observed by placing a camera near our eye and processing work may be done using image acquition toolbox of matlab
  7. wayneh
    Sep 9, 2010
    12,374
    3,226
    I can't help with any of that, except to help define the needs.
    Are you planning to hold the head fixed, so that the camera can be fixed on the pupil? If the camera must track the eyes as they move with the head, that will be a very complex assembly. Perhaps a facial recognition app can determine head position, but then you would still need to determine eye position.
    And the laser; will it be mounted on a tripod or such, with 2 axes of movement? That should be a relatively easy aspect of the project.
  8. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    I suspect the OP is woefully unprepared for such a project.
    #12 likes this.
  9. Kermit2
    Feb 5, 2010
    3,846
    963
    Perhaps not eye movement, but helmet, or other head gear device can be servo'd to the laser position drivers. Then a 'bulls eye' sighting marking can be used by the wearer to position the helmet on the object that needs to be blasted by laser light. :)
  10. djsfantasi
    Apr 11, 2010
    2,900
    874
  11. atferrari
    Jan 6, 2004
    2,663
    783
    Head or eyes?
    Are you sure you have clear idea of what you intend to design?
  12. wayneh
    Sep 9, 2010
    12,374
    3,226
    The rest of us certainly are not. :p
    Happy New Year!
  13. kalaivendhan
    Dec 29, 2013
    6
    wayneh likes this.
  14. kalaivendhan
    Dec 29, 2013
    6
    okay friends,i'm intend to my final year project in wireless or matlab based processing along with embedded...can anyone suggest me any ideas...please...
  15. wayneh
    Sep 9, 2010
    12,374
    3,226
    Do you believe that your proposed project meets the requirements? If your teacher is aware of that linked project, will you get credit for reverse engineering what was already done there? I think it would be a challenging project if you start with nothing, but it will be far easier (too easy?) to copy that existing project.
    kalaivendhan likes this.
  16. kalaivendhan
    Dec 29, 2013
    6
    ya i'm really interested to start with nothing as you said... so only i'm searching for new ideas..pealse guide me
