even number counter design
Discussion in 'Homework Help' started by Xufyan, May 24, 2011.
  1. Xufyan
    Aug 3, 2010
    114
    i have a problem designing a 4-bit even number counter.,
    the states of the counter is,
    0000 = 0
    0010 = 2
    0100 = 4
    1000 = 8
    in each number the LSB is '0'
    so when i draw the karnaugh Map of J0 is filled with 0s and K0 with 'X' (Don't Care) ?
    am i doing something wrong ??
    Edi: Problem solved !!
  2. RiJoRI
    Aug 15, 2007
    536
    26
    "Edi: Problem solved !!"
    Care to share your solution for other seekers?
    My QnD (Quick & Dirty) solution would be to connect the counter output lines to the next highest input line:
    O0 -- I1
    O1 -- I2
    O2 -- I3
    O3 -- Not connected
    I0 is grounded.
    --Rich
  3. Xufyan
    Aug 3, 2010
    114
    Jo is grounded
    and its really don't care either Ko is connected to Vcc or grounded because in both situations
    the output for the flip flop remains '0'.
    Jo=0(ground) , Ko=1 =>> Output = '0' (Reset)
    Jo=0(ground) , Ko=0 =>> Output = '0' (No change)
    Since Jo is grounded therefore there will be no situation where Output is equal to '1' ,
    it always remain 0.
