Euler's method
Discussion in 'Math' started by boks, Dec 11, 2008.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    x'' - 2x' + x = 4t, x(0) = 1, x'(0)=1
    Introducing y_1 = x and y_2 = x'
    we have the system
    y_1 ' = y_2
    y_2 ' = 2y_2 - y_1 + 4t
    right?
    Using Euler's method with step size h=0.1, we get
    y_{1, n+1} = y_{1, n} + 0.1y_{2,n}
    y_{2,n + 1} + 0.1(2y_{2,n} - y_{1,n} + 4t)
    It's easy to see that y_{1, 1} = 1 + 0.1 \cdot 1 = 1.1, but what is y_{2,1}?
  2. blazedaces
    Jul 24, 2008
    130
    What issues do you have with euler's method? What don't you understand? Why are you asking us to do simple problems for you?
    -blazed
  3. boks
    Oct 10, 2008
    218
    Updated first post.
  4. blazedaces
    Jul 24, 2008
    130
    I don't see what the issue is here man...
    Well, first of all, I'm going to see that by:
    You actually meant:
    y_{2,n + 1} = 0.1(2y_{2,n} - y_{1,n} + 4t)
    In which case
    y_{2,1} = 0.1(2y_{2,0} - y_{1,0} + 4t)
    You have y_{2,0} and you have y_{1,0}.
    Proceed. Good luck.
    -blazed
    Edit: Your t should be t_n where t_{n+1} = t_n + h
  5. steveb
    Jul 3, 2008
    2,433
    469
    Actually, this is a good question and this issue can be a point of confusion when first learning. One often hears of Forward Euler and Backward Euler methods. The forward method is probably what you are using since it is more common and I think BlazedAces' answer is correct for that approach. However, in the backward Euler method the time value would be t(n+1) instead of t(n).
    Anyway, I thought I'd mention that since what appears to be a simple problem can often have little points of confusion.
    This simple Forward Euler method is generally not used for numerical analysis since the accuracy is much poorer than higher order methods. However, it is often used in real-time micorprocessor based control systems since the calculations can be perfomed quickly and with minimal delay.
  6. boks
    Oct 10, 2008
    218
    Yeah, it's the forward method. Then I use t(n)
