Ethernet Layout
Discussion in 'General Electronics Chat' started by sstbrg, Jul 19, 2011.
  1. sstbrg
    Thread Starter Active Member
    Nov 29, 2008
    54
    Can I place ethernet lines (MDIA+,MDIA-,MDIB+...) on a PCB?
    I want to design a board that has two RJ-45, without a PHY component. Do i need to use isolated coils? do i need to consider impedance matching?
    Thankyou,
    Danna
  2. studiot
    Nov 9, 2007
    5,005
    515
    If you mean you want to connect two RJ45 devices in parallel you can only do this if one does not respond to signals eg for a monitor scope connection.
    If you mean you want to provide two separate RJ45 connections via IP by using the redundant lines in an ehternet cable you can do this.
    go well
  3. sstbrg
    Nov 29, 2008
    54
    you didn'y understand me.
    I want to connect a cable to a board with RJ-45, pass ethernet lines through the board (without using them) and connect them through another connector (NOT RJ-45).
    thank you,
    Danna
  4. TBayBoy
    Member
    May 25, 2011
    148
    19
    I'm still new at all this, but I don't understand what your asking either :(
  5. studiot
    Nov 9, 2007
    5,005
    515
    Of course I didn't understand you. You specified two RJ45, now you say there is only one.
    Make up your mind.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    CAT-5 uses four twisted pairs so that noise will be cancelled out.
    If you're going to route the signals across a board, you'll need to ensure that you won't get coupling between other pairs. You might run a ground strip between them to provide a barrier.
