Ethernet conductor in PCB
Discussion in 'General Electronics Chat' started by Danna, Jul 23, 2011.
  1. Danna
    Jul 23, 2011
    I want to pass ethernet conductors through a PCB,the input is from RJ-45 and the output is to a circular connector.
    Do I need to match impedances on the board? do I need to add capacitors/resistors?
    *I don't use the the trasmitted data, meaning I don't use PHY component.
    Thank you,
    Danna
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, you might do that, but you don't say what else will be on the board.
    CAT-5 cable has 4 twisted pairs inside; 2 pairs for data and 2 pairs for voice. The twisting keeps the signals from coupling to other pairs.
    If you run the signals across a board without some kind of shielding, they may pick up ambient noise or noise from the board; they won't be twisted any more unless you make the traces "twist".
    [eta]
    Here's an application note from Micrel: http://www.micrel.com/_PDF/Ethernet/app-notes/an-111.pdf
    You should have a look.
  3. Danna
    Jul 23, 2011
    I also have on the board a lot of components (FPGA,prom,trancievers, clocks,SRAM,flash and etc).
    how do I keep the twisting on the board? Do I use 100ohm controlled trace and Keep both traces of each differential pair as identical to each other as possible?
    Thank you,
    Danna
