Etching PCB board....
Discussion in 'General Electronics Chat' started by RRITESH KAKKAR, Feb 5, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    What would be the diff in result by using Ferric chloride anhydrous and combination of Mix Hydrochloric acid to Hydrogen peroxide in a ratio of 2:3 and drop your copper board into it. Within 5-10 seconds, you can see the copper removed from the board and tracks clearly visible.
    I was etching PCB but it was not etching properly taking time too much but not satisfy result.
    http://www.instructables.com/id/PCB...Etching-and-removing-toner-from-copper-board/
    Need help!
  2. GopherT
    Nov 23, 2012
    6,303
    4,019
    Anhydrous means "water free". So first, it must be dissolved in water.
    Both methods work and you will find people with different opinions - some will like ferric chloride and some will like H2O2/HCl solution.
    Which method have you used? Why do you want to switch?
  3. sirch2
    Jan 21, 2013
    1,008
    351
    Ferric chloride works much faster if heated to about 40C
  4. shortbus
    Sep 30, 2009
    4,088
    1,670
    And if it is agitated. I use a disposable foam paint brush to move the ferric solution over the the copper and it causes the etch to work much faster. Moving the already etched material and letting new copper to be exposed to the ferric.
