Etching circuit boards?
Discussion in 'The Projects Forum' started by bmxerds, Feb 11, 2013.
  1. bmxerds
    Sep 4, 2012
    16
    Hello everybody do you guys think it is possible to etch a circuit board by painting out a pattern with regular enamel spray paint?
  2. wayneh
    Sep 9, 2010
    12,377
    3,231
    The paint almost has to slow the etching process compared to the naked copper around it. The only way this wouldn't be true is if it quickly dissolves or reacts away when exposed to the etching solution. You could answer that - and your overall question - with a quick test. I predict it will be fine.
    Be sure to specify which etching chemistry you plan to use - it might matter.
    bmxerds likes this.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    Most permanent markers work well. If you have already cut out a stencil to spray paint, it's not much extra work to go around it with a marker.
  4. DickCappels
    Aug 21, 2008
    2,758
    667
    I have made many low-resolution PC boards by painting the pattern with fingernail varnish, using both Ferric Chloride and the Nitric Acid/Hydrogen Peroxide solutions.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    I don't like Nitric Acid much, but hydrochloric acid works just as well.
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    Try a Sharpie or similar marker pen.
  7. spinnaker
    Oct 29, 2009
    5,065
    1,173
    I have wondered if anyone had modified an ink jet printer to spray on the PCB design.
    The problems I see are choosing the right kind of ink to resist the etchant enough and more important not to run.
  8. spinnaker
    Oct 29, 2009
    5,065
    1,173
    Actually a vinyl based spray paint might work if one exists.
