Hi all,
My question is somewhat fundamental:
If i take a regular step down transformer, say 120VAC on the input, 12VAC, 1A at the output, designed for 50/60 hz and i feed it a 5v p2p signal from a voltage generator into the secondary winding and i am getting 50v 2p2 at the primary around 50hz-1000hz region.
However, I've noticed that as i go higher in frequencies, the voltage at the output increases.
My question is: how can i roughly estimate the power loss as a function of frequency ?
(My motivation behind this type of tinkering is building a low cost, variable frequency high voltage AC signal, so i want to know how much power will i be able to produce at the output, I intend to use a salvaged microwave transformer fed from an audio amplifier which is fed from a signal generator ).
If you have any reservations regarding this type of configuration, I would appreciate your feedback.
Regards,
Lenny
Regards,
Lenny
