I have a few minor edits to suggest for the ESD article
http:// www.allaboutcircuits.com/vol_3/chpt_9/1.html
In a couple of places, the current that may be associated with static electricity is treated a little too casually, in my opinion, as in the quotes "there is no current capacity behind it. " and "Static electricity is voltage with no real current".
Static electricity may discharge in a wide range of currents, both small and large (think lightning) so I think that low current when the stored charge flows is not a consistant property of static electricity.
Is this quote from the article really true: "pulling tape off a dispenser can generate millions of volts"? I'd be surprised. Most articles I've casually browsed suggest that a million volts will spark at least several feet! I can't imagine a tape dispenser generating this much voltage.
And about this quote "continuously bleeding off this voltage is needed." I would say that what is bled off is charge. Voltage is a property of this charge, and while it's true that bleeding off charge results in bleeding off voltage, I think that charge is more fundamental thing.
