Esaki Effect LED Flasher
Discussion in 'The Projects Forum' started by so54i88, Jun 15, 2011.
  1. so54i88
    Sep 23, 2010
    Hello all...I've been experimenting with different simple led flasher circuits with minimum number of components. I like the effect achieved by Easki circuit but it requires 12v or more. Can someone enlighten me what this is the case? Ideally, I'd like to use a 3-6v power source. Can someone help me please? Thank you in advance.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Perhaps you can give us a link to the Easki circuit?
  3. #12
    Nov 30, 2010
    16,665
    7,313
    Like the man said in the video, it absolutey, positively, must be (at least) 12 volts because you are depending on the reverse breakdown voltage of the base-emitter junction. They often require 7 to 9 volts to break down like a zener diode.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    And on top of the 7 to 9v to break down the PN junction, you need a few more volts for the LED and the voltage drop across the resistors in the circuit.
    You would need to build a boost converter circuit to run it from lower than 12v, but that defeats the point.
  5. #12
    Nov 30, 2010
    16,665
    7,313
    I would like to correct myself...
    I remember that there is a certain part number of transistor that is sorted for less than 6 volts reverse breakdown, but I can't remember the part number. Still, even with a transistor that is sorted for low breakdown voltage, add the LED voltage and base to collector junction, you could maybe, just barely do it with 9 volts...maybe.
