Error while running LVS using Cadence
Discussion in 'Electronics Resources' started by Joe24, Jul 29, 2008.
  1. Joe24
    Thread Starter Active Member
    May 18, 2007
    52
    29 Jul 2008 20:16 Error while running LVS on Cadence
    Hello all,
    I am having an error when I run LVS using Cadence. The error states:
    Invalid LVS run directory
    You must initialize the LVS run with a valid LVS run directory
    before you can probe.
    I have no idea what this error is or how to fix it. I have never seen it before.
    Can someone give me an idea of how to get rid of it? Thanks alot.
    by the way, I should mention that I am not an expert with cadence, Im familiar with the basics and am just learning it. So if you can please explain as if talking not to an expert but an newbie. Thanks again.
  2. Dieds
    Jul 29, 2008
    Not to thread-jack, but Cadence just launched a new user community. If no one here can help, check over there and then paste what you learn here to help other folks with the same issue.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I recall similar issues some time back. IIRC you need to set the CDS_Netlisting_Mode to value "Analog" - this allows LVS to run as normal.
    How slow is that user community? Btw, I have edited your link in-line with our rules on advertising.
    Dave
  4. Joe24
    May 18, 2007
    52
    Yes that's right. I visited the site. But it is not that straight forward to post a question. I was navigating throught the site for a while, and registered as well. At the end, I was not able to find a way to post my question. I am able to view other posts, but not sure how to post.
    Maybe something I am not seeing.
  5. Joe24
    May 18, 2007
    52
    Thanks Dave. But again, I am relatively new to Cadence, so the next question to you would be: How do I change the mode to Analog??
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    It is over 3 years since I have used Cadence and the information I am giving is gleamed from my old logbook, so this is given without warranties. Firstly, you need to veryfy that the CDS_Netlisting_Mode mode is set correctly; i.e. you need to ascertain if your mode you are working in is "Analog" or "Digital".
    At the CL, type:
    Code ( (Unknown Language)):
    1. getShellEnvVar("CDS_Netlisting_Mode")
    What do you get?
    Dave
  7. Joe24
    May 18, 2007
    52
    So I tried this, and I did not get any message. Would you know how to do it using the GUI?
