Error when importing MPP file (Mircosoft Project)
Discussion in 'Computing and Networks' started by jeremybryan279, Oct 9, 2015.
  1. jeremybryan279
    Oct 8, 2015
    Hi, today I tried to import an mpp file and I got the following error:
    java.class.path: eclipsito.jar;.
    java.home: C:\Program Files (x86)\Java\jre7
    java.ext.dirs: C:\Program Files
    (x86)\Java\jre7\lib\ext;C:\windows\Sun\Java\lib\ext C:\Users\peter.danailov\AppData\Local\Temp\
    java.runtime.version: 1.7.0_51-b13
    java.vendor: Oracle Corporation Java HotSpot(TM) Client VM
    java.vm.vendor: Oracle Corporation
    java.vm.version: 24.51-b03
    os.arch: x86 Windows 7
    os.version: 6.1 org.bardsoftware.eclipsito.Boot
    ganttproject-eclipsito-config.xml -log US
    user.dir: C:\Program Files (x86)\GanttProject-2.6
    user.home: C:\Users\peter.danailov
    user.language: en
    user.timezone: Europe/Minsk
    Is there a way to stop this error?
  2. Casassa
    Oct 10, 2015
    How big is your mpp file? You may try increasing the amount of memory available
    to Java Runtime. Unfortunately you can't do it for ganttproject.exe (which is
    associated with GanttProject shortcuts in Windows menus) but you can do it for
    ganttproject.bat which comes with ZIP distro (and with Windows distro too,
    AFAIR). Try replacing -Xmx512m with -Xmx1024m in ganttproject.bat and start
    that bat file.
    Moderators note: removed commercial link
    jeremybryan279 likes this.
  3. LeslieGarner
    Oct 18, 2015
